Unstyled JD G
Aaron S
01-21-2008 17:59:00
Will a late flathead from a G s#7100 and up fit on to a G Block s#1000-7099. I know there are some differences in the cooling passages. Has anyone tried this. In my mind I can't see how it will seal the water jackets from the pushrods. Thanks Aaron
Drew
01-21-2008 18:38:18
 Re: Unstyled JD G in reply to Aaron S, 01-21-2008 17:59:00
You are correct, the water passage in a F486R head will dump water down the pushrod passage on a F48R block. I think you will be time ahead to find either a F485R block to go with your head or find a F49R head to fit your block.
Aaron S
01-22-2008 02:56:01
 Re: Unstyled JD G in reply to Drew, 01-21-2008 18:38:18
Anyone have the F485 block for sale. Or is anyone interested in The Late flat head. Just come back from the machine shop with all new valves, guides, springs, etc as needed. Thanks Aaron
long hauler
01-24-2008 16:00:07
 Re: Unstyled JD G in reply to Aaron S, 01-22-2008 02:56:01
give me a email with the cost. thanks
long hauler
01-24-2008 15:59:44
