farmall m pulling hitch on ebay
points puller
01-22-2008 08:26:10
i got one from him about a year ago. pulled all year with it it adj easy and is also p.t.o. delete cover
Drew
01-23-2008 17:22:40
 Re: farmall m pulling hitch on ebay in reply to points puller, 01-22-2008 08:26:10
The best I can tell from the pictures; the only thing above the center of the rear axle is part of the top stop screw for the drawbar. Unless there is something in the pictures on ebay I'm not seeing, this is a safe type of drawbar. If something were to break, the drawbar would pull straight out and that would be the end of it.
To the other posters: I 110% agree a TURNBUCKLE above the center of the axle is a bad idea!! Saw a guy d@mn near get killed when an IH-M came over backwards because part of the hitch broke and all that held was the adjusting turnbuckle way up by the seat.
LEGAL
01-24-2008 11:12:11
 Re: farmall m pulling hitch on ebay in reply to Drew, 01-23-2008 17:22:40
Drew you are missing the factors! The swing drawbar that is hooked under the rear of the transmission were to break the coupling (or break a hole out of the transmission) and that piece could not pass through the opening, that drawbar could come at such a force as to snap all bolts except the top two. Where would the hitch be pulling from? Above the axle!! Anything is possible guys. Think safety! One accident is to many.
points puller
01-23-2008 10:36:34
to safety or legal who ever you are. i had 21 hooks in divison 2 and 3 in 07. nobody said anything about the hitch on my tractor. it still pulls from stock drawbar.so what is the problem.
LEGAL
01-23-2008 14:34:47
 Re: farmall m pulling hitch on ebay in reply to points puller, 01-23-2008 10:36:34
Points puller you didn't say what make of tractor you pull. Safety wise I realy don't care, but if the hitch is attached any where above the center line of rear axle it could be a safety issue. If you are hooking and no one is saying anything about it then it is not in their safety rules. Go have fun.
whatintheworldiswrong
01-22-2008 15:16:19
i wish you people would stop mentioning that stuff on here, your driving up the price. lol
PGpower
01-22-2008 12:15:49
stock hitch is only 16" high and is not trying to 'lift' a sled. totally different application.
and, we probably know more about safety today than we did in the 40's and 50's, so lets use this knowledge to be as safe as possible.
SAFETY?
01-22-2008 09:55:43
AT MOST PLACES THAT HITCH WOULD NOT BE LEGAL. IT PULLS FROM ABOVE THE CENTER OF REAR AXLE. WE GOT TO THINK SAFETY GUYS!!! IF THE LOWER BOLTS WOULD SNAP AND PULL FROM THE UPPER MOST TWO BOLTS IT WOULD SLAP THE WHEELIE BARS AT SUCH A FORCE IT COULD COLLAPSE THEM. NATPA MADE IT A RULE FOR SAFETY.
superih
01-22-2008 14:32:53
 Re: farmall m pulling hitch on ebay in reply to SAFETY?, 01-22-2008 09:55:43
130192147082
Is this what you are talking about?
If so it pulls from under the tractor by the stock swinging drawbar location.
LEGAL?
01-22-2008 09:50:31
AT MOST PLACES THAT HITCH WOULD NOT BE LEGAL. IT PULLS FROM ABOVE THE CENTER OF REAR AXLE. WE GOT TO THINK SAFTY GUYS!!! IF THE LOWER BOLTS WOULD SNAP AND PULL FROM THE UPPER MOST TWO BOLTS IT WOULD SLAP THE WHEELIE BARS AT SUCH A FORCE IT COULD COLLAPSE THEM. NATPA MADE IT A RULE FOR SAFTY.
41 Year + Puller
01-22-2008 18:00:32
 Re: farmall m pulling hitch on ebay in reply to LEGAL?, 01-22-2008 09:50:31
NATPA seems to think that all makes must use
John Deere type drawbar. A true stock Farmall
is not legal with it standard drawbar.
supermpuller
01-22-2008 11:40:25
Have you ever looked at a stock IH hitch on a M, or H , they pull from above the center of rear axel, and I haven't seen wheelie bars on a old H working on the farm yet.
jhb
01-24-2008 05:41:51
 Re: farmall m pulling hitch on ebay in reply to supermpuller, 01-22-2008 11:40:25
Not with the swinging drawbar in place.
