JOHN DEERE R
ALAN IN SD
02-06-2008 15:24:02
OVERHAULED THE MOTOR ,PUT 730 PISTONS IN WITH 730 INJECTORS. NOW WILL HARDLY RUN, LOTS OF BLACK SMOKE, VERY SLOW THROTTLE RESPOSE . WILL NOT REV UP TO FULL RPM. HELP! ANY AND ALL IDEAS WELCOME. THANKS,ALAN
ALAN IN SD
02-07-2008 16:17:49
 Re: JOHN DEERE R in reply to ALAN IN SD, 02-06-2008 15:24:02
THANKS FOR ALL THE ADVISE, RUNS GREAT NOW! THANKS AGAIN
Trkr
02-07-2008 18:00:08
 Re: JOHN DEERE R in reply to ALAN IN SD, 02-07-2008 16:17:49
Glad to hear it,had me baffled the first time I built one too.Good luck,thanks for posting back.
ALAN IN SD
02-07-2008 06:58:00
THANKS FOR ALL THE ADVISE ,I'LL CHECK IT OUT AND LET YOU KNOW. ,THANKS AGIAN,ALAN. P.S. LOCATED IN NE SD, ABERDEEN
Trkr
02-06-2008 18:33:25
Had the exact same problem on an R I built for a guy several years ago with the same components.The 730 injector tips are not sticking far enough into the combustion chamber on the R head and are not atomizing the fuel.Remove the coppers and put the injectors in for a test run without them.I had to grind the injectors down so they would fit.Let me know.
ALAN IN SD
02-06-2008 17:44:10
NO AIR CLAENER HOOKED UP YET. THE INJECTOR TIPS LOOKED THE SAME ,SHOULD I HAVE DONE SOMTHING OTHER THAN NEW COPPERS?
skip33652
02-06-2008 19:15:16
 Re: JOHN DEERE R in reply to ALAN IN SD, 02-06-2008 17:44:10
Alan the injector tips On a R are tapered starting at about 5/16" and going to about 3/16" maybe a bit less the 730 tips are basically straight at about 5/16". in order to get injector to seat in correct position. you either need to drill head out or grind injector tip down like the R tip. I have heard of doing it both ways I just drill head out.so it is like the early 70-720 80-820 heads.wher in SD are you? I am in the south west part near MartinPaul
skip33652
02-06-2008 16:36:19
first off check your air supply.and or maybe eliminate air cleaner to double check that .next did you drill head out so injectors seat down .dumb question I know but forgive me. next is rack moving correrctly? paul
