piston specs
263 build
02-08-2008 13:21:14
is there a website with dementions? what i really need to know is how far i can take my 263 safely. will a 291 piston drop right in. and are they available? thanks
ChadS
02-09-2008 08:11:27
 Re: piston specs in reply to 263 build, 02-08-2008 13:21:14
291 with sleeves, youll be OK!! 301 with no sleeves, your OK too!! the 263-301 had the same crank and rods, same stroke, just a bigger bore piston. .060 over the 301 piston specs, and you will have problems over time,,, but at STD bore 301,, 3.8125 bore,, the engine can live for a long time and not risk block failure. ChadS ChadS3@hotmail.com
