jd 466 block weight differences
algar
02-11-2008 17:50:28
Does anyone have any data on the weight of 466 blocks I have heard they are all close in weight to 200 lbs diff. I have a block out of a 4840.
jd b puller
02-12-2008 19:10:54
 Re: jd 466 block weight differences in reply to pullerboy624, 02-11-2008 17:50:28
depends which rods you have in there.
4010 gas rods are 7.75" c/c.
4010 diesel I THINK are 8.75" c/c
High Octane
02-12-2008 05:45:48
 Re: jd 466 block weight differences in reply to algar, 02-11-2008 17:50:28
Algar, you wouldnt have an extra rod and piston out of that JD 466 do ya?? Looking for some measurements,,, center to center rod length, and compression height on the JD piston are what Im looking for,, Email is open! Thank you any help would be grreat!
algar
02-12-2008 16:45:19
 Re: jd 466 block weight differences in reply to High Octane, 02-12-2008 05:45:48
I don't have it apart that far,It has 4010 rods in it. If I do I will let you know
ejr-IA
02-12-2008 11:59:36
The compression height is 2.766 don't know the rod c to c.
