hitch position????
263 build
02-19-2008 13:00:18
36 in. is waaay to far back. that's double any rules i've heard of. the downward pull will change drasticly if pulling from in front or behind the axel. if at all possible i wouldn't pull from the draw bar. that will change balance if attached at center of tractor. if you get to much down pressure from the sled a stock motor will run out of power. i'm set up 19-20 in. high 18 in. from center of axel with my hitch attached about 3 in. in front of axel. very balanced for me. i can't picture a mini mo hich in my head though. so maybe i'm way off.
