John Deere 730 D
A pulling
02-22-2008 19:32:38
What can be done to John Deere 730d to add horsepower and still do a little farm work? What horsepower could be expected with a little work?
buickanddeere
02-27-2008 08:44:00
 Re: John Deere 730 D in reply to A pulling, 02-22-2008 19:32:38
B-maniac
Yes you are correct, I'm sorry. What did I think I was doing talking those topics on this site.
It's all about buidling an engine to 3-4X over factory HP and still calling it stock.
gpuller
02-26-2008 06:21:52
 Re: John Deere 730 D in reply to worried puller, 02-22-2008 19:32:38
buickanddeere said: (quoted from post at 18:59:47 02/25/08) Blackdash 720 & 730 already has the 13mm pumps from the factory. If memory serves the 820 blackdash/830 injector tips did flow more than the late 720/730 tips.
All 720's had 13mm pumps, the service manual has a note not to use the pump calibration for the 70D because they used the 10mm pumps.
By larger pumps, I'm talking custom built internal parts to make a factory 13mm pump a 14mm. The injectors have new tips with larger holes for more fuel flow. Factory tips for 720/30 have a different spray angle (140deg), compared to the 820/30 (160deg).
buickanddeere
02-25-2008 17:59:47
gpuller
02-25-2008 09:25:25
You didn't mention the condition of the big engine. If it has been overhauled you can add more fuel with larger injector tips or even larger fuel pumps. A dry air filter conversion helps too.
Can get 70-80hp depending on if you do injectors or pumps along with injectors, and still do your farm work.
buickanddeere
02-22-2008 19:34:45
You don't need to add power. The three most important factors to look after first are traction, traction and traction.
Put the tractor on a dyno and see if it's making rated HP before trying to soup it up.
How deep are your pockets?
What class are you pulling in?
B-maniac
02-26-2008 19:03:00
 Re: John Deere 730 D in reply to buickanddeere, 02-22-2008 19:34:45
Now now B&D, you know it's not right to talk "stock power" or "traction" on this forum. How dare you?
