spark plugs
Bpuller
02-28-2008 19:07:54
What 14mm spark plugs are you guys using in your JD's Any help would be appreciated
buickanddeere
03-05-2008 19:38:15
 Re: spark plugs in reply to Bpuller, 02-28-2008 19:07:54
That's odd. I was certain I had typed in a few samples of 19mm / 3/4 reach 14mm plugs with this mornings reply. Must have been 1/2 asleep and lost then with the spell checker?
NKG 2552,R7112-7 or 2846,R7116-9 Autolite XS4064,XST2976 or SM4251 Denso 3238,P20R11.
Sparkplugs for snowmobile engines tend to a very long reach plug.
JDGnut
03-05-2008 09:47:44
 Re: spark plugs in reply to 560 Farmall Puller, 02-28-2008 19:07:54
I'm not sure on the part number.. (I still haven't ordered a set.) but try ordering a set for an Allison Aircraft engine.. (you'll probably have to get a part number.. I dont think they'll be able to look it up..) but they will have longer threads, and will push the electrode further into the cylinders..
JDGnut
jd b puller
03-02-2008 07:41:51
 Re: spark plugs in reply to superih, 02-28-2008 19:07:54
Glen, please send me an e-mail, I need to talk to you...
jdbpuller@earthlink.net
Thanks,
buickanddeere
03-04-2008 17:33:59
 Re: spark plugs in reply to jd b puller, 03-02-2008 07:41:51
Working night.I"ll try getting the info from home later. This computer at work has a firewall that doesn"t accept my favorite spark plug search site.
jd b puller
02-29-2008 18:59:03
buickanddeere said: (quoted from post at 22:50:58 02/29/08) Autolite 3116 or AC C88L.
B&D, he's asking about 14mm plugs... Does it matter whether you're running MSD, Distributor, or Mag? (Resistor/non)
buickanddeere
03-05-2008 07:05:29
 Re: spark plugs in reply to jd b puller, 02-29-2008 18:59:03
Link
For a mag, definitely solid core wires and non resistor plugs. Same advice for distributors unless somebody is using an AM radio in the immediate area. Some electronic systems require a resistor or inductive wire between the coil & distributer to limit current.
buickanddeere
03-01-2008 23:19:22
You are correct, I had 18mm in mind. Autolite 216 or 473. There is a non resitor platium Atolite but the number excapes me at the moment.
buickanddeere
02-29-2008 18:50:58
UNSTYLED PULLER
02-29-2008 14:34:57
HELLO,,
DONT MATTER AS LONG AS IT IS A BLACK PLUG,, LIGHT COLORED PLUGS DON'T RUN GOOD IN DEERE'S
I RUN AUTOLITES, 3077 IN UNSTYLED TRACTORS..
Scott Boehler
02-29-2008 07:17:18
I use NGK A6 plugs in my G. Might go under part
#1010 or poss AB-6
Hot Rod A
03-02-2008 13:32:17
 Re: spark plugs in reply to Scott Boehler, 02-29-2008 07:17:18
Just remember your ABCs...anything but champion!
