JD 70
BIGMONEY
03-03-2008 12:31:42
DOES ANY ONE KNOW WHAT THE COMPRESION PSI IS FOR A JD 70 GAS AND JD 70 LP
JDGnut
03-07-2008 17:30:01
 Re: JD 70 in reply to massey333, 03-03-2008 12:31:42
BIGMONEY said: (quoted from post at 13:31:42 03/03/08) DOES ANY ONE KNOW WHAT THE COMPRESION PSI IS FOR A JD 70 GAS AND JD 70 LP
All Fuel 4.60
Gas 6.15
LP 7.30
Not the biggest change.. but it will be noticable...
JDGnut
buickanddeere
03-05-2008 19:15:50
 Re: JD 70 in reply to BIGMONEY, 03-03-2008 12:31:42
Everybody that has their operator's manual knows.1-800-522-7448.
BIGMONEY
03-06-2008 10:51:28
 Re: JD 70 in reply to buickanddeere, 03-05-2008 19:15:50
WHAT I AM TRYING TO FID OUT IS HOW MUCH COMPRECTION MY TRACTOR THAT IS NOW GAS WIL GAIN
BY PUTTING LP PISTONS IN IT WHEN I OVERHAUL IT
BECAUSE THE ONLEY DIFFERANCE IN GAS AND LP MOTERS IS THE VALVE SEATS ARE HARDER/AND HIGHER COMPRECTION PISTONS/THANKS FOR ANY HELP ANYONE
buickanddeere
03-06-2008 19:54:43
 Re: JD 70 in reply to BIGMONEY, 03-06-2008 10:51:28
All Fuel 70 was 4.50 to 1 compression ratio with 95 psi cranking pressure. How about a set of standard size G pistons in there? Just mill them a little to fit and run 100LL.
BIG MONEY
03-05-2008 18:37:34
LOOKS LIKE IF I FIND THIS OUT I WILL BE THE ONLEY ONE IN THE US THAT KNOWS
