Dekalb Results???
jd b puller
03-02-2008 21:00:26
Are they posted anywhere? Thanks.
Restless Kind
03-16-2008 10:01:52
 Re: Dekalb Results??? in reply to jd b puller, 03-02-2008 21:00:26
My guess is that was a typo. And if you want to pull with the NATPA then go to their website to check out their rules for each classes.
www.natpa.com
jd b puller
03-04-2008 21:19:31
 Re: Dekalb Results??? in reply to Larry59, 03-02-2008 21:00:26
Thanks for the update. Looked like good turnout except for the 3500, and there wasn't a 4000. Wonder how many more 3500# tractors would have showed up if they had more than one class to pull in?
What happened to the 4500# class? I copied the rules from the COATPA website, I must be missing something.
"OTHER RESTRICTIONS
Oliver 88, Farmall M, Massey 44, MM-U, JD-G, Case-C/D, JD-A 1940 and up and like size tractors are not allowed in classes below 4501#. Massey 33, Oliver 77, JD-A 1939 and down and like size tractors are not allowed in classes below 4000#."
Call me crazy, whiner, whatever, but I was pretty sure that 4500# was less than 4501#.
9 of the 19 tractors in the 4500 Div II were 44's, 88's and M's.
When going to an NATPA pull, what rules are you supposed to follow?
Gary H.
03-04-2008 17:11:56
Go to Central Ohio"s website. They"re on there.
