Rim Width
1600 Puller
03-04-2008 08:00:22
I have a set of 18.4-38 BFG Power Grips on 16'' rims and I am considering spreading the rims. How wide should I spread them to get the most traction from these tires? The tires are bias ply with about an inch of lug. We are not allowed to run cuts.
LEGAL
03-04-2008 08:43:52
 Re: Rim Width in reply to 1600 Puller, 03-04-2008 08:00:22
Spread your rims to 20" for the best results. Tire will sit flatter to ground. Keep an eye on your dig marks for best tire pressure. I've used 20" rims for years on 18" tires.
Tater
03-09-2008 08:56:01
 Re: Rim Width in reply to LEGAL, 03-04-2008 08:43:52
Hey guys, I' m running 20'' rims if I let tire pressure to low I pinched my tubes on a regular baises, keep your pressure above the tractor weight on a per thousand rule...ie: 10,000 run above 10 Lbs.
