ChadS
03-14-2008 18:36:52
Re: Farmall 300 gas and 504 gas cam specs in reply to FarmerSid, 03-06-2008 04:40:40
Sid,I had a chance to sit down with a 300 gas head this week, stuffed the chamber full of clay, and then, took a brass hammer and tapped the valve into the clay,,, I was able to measure how much valve travel the stock spring could handle without binding, and I came up with no more than .350 of actual valve movement before it bottoms out the spring. On the cam Im running in my H, I have to make room for more travel, dont know If im gonna find a custom spring, or cut more area under the spring to give more room for travel. Havent decided yet,,,,, Still digging up the cam specs,, found the cam card for Something Wilder though,,,,, I thought the two cards were together,,,, darn it!! Ill keep lookin. Hope this helps a little,,,,, ChadS ChadS3@hotmail.com
