Jonh Deere 60 VS John Deere 70
cat988
03-08-2008 04:29:34
looking to pull which tractor is better to use?John Deere 60 or John Deere 70 thanks
gpuller
03-11-2008 14:19:09
 Re: Jonh Deere 60 VS John Deere 70 in reply to cat988, 03-08-2008 04:29:34
JDBert said: I'd take the 70- the fast first gear is a "fixable" deal
Sure its "fixable" but they still come up a bit short on power if you start running 8500-9500lb class. Even if they have M&W's.
Take the 60.
JDBert
03-11-2008 11:37:19
 Re: Jonh Deere 60 VS John Deere 70 in reply to trulyred, 03-08-2008 04:29:34
jd b puller
03-10-2008 20:47:50
 Re: Jonh Deere 60 VS John Deere 70 in reply to 560 puller, 03-08-2008 04:29:34
We used to run a JD 70 in the 5500-7500# class. No Stroke, just powerblock and some crazy cam. Used to pull up at Wooster OH back in the early/mid 90's. If anyone has any pics of it on the track (at night) could you send them to me? It'd be the one with about a 2 foot tall blue wafting flame at idle, and would get rather pointy on the track. Pulled OK, but geared way too high, especially if you weren't paying attention and had it on the high side...
BIGMONEY
03-10-2008 14:21:14
I HAVE SEVERAL PULLING TRACTORS AND ONE IS A 70
AND IT IS THE WORST PULLING OF ALL OF THEM IT DONT HAVE CREAPER FIRST GEAR BECAUSE IT HAS LOW AND HIGH RANGE TRANS/ I WOULD OF NEVER RIGED IT OUT FOR PULLING IF I KNEW THAT FIST BEACUSE FIRST IS WAY TO FAST LUGS DOWN QUICK
G0 WITH THE 60
JDGnut
03-10-2008 19:24:46
 Re: Jonh Deere 60 VS John Deere 70 in reply to BIGMONEY, 03-10-2008 14:21:14
I think it depends on what kind of modifications you want to do to the tractor. In stock form the 60 tend to do better because of the low gear. (Espeically with bigger tires.) but modified.. The 70 would do better in a 3.5-4 mph class, because it will run at the limit with bigger tires.. the 60 will be well be low the limit..
The 60 will also accept most of the modified parts as the late A's..
JDGnut
johndeereman
03-08-2008 09:16:44
pound for pound the 60 is a better tractor the 70 is heavy and all it likes to do is drink fuel in tractor pullin its not how much power you have it comes down to a power to weight ratio you need just the right amount of power to the weight to much power you will spin to little it will die
Big Jake 60
03-08-2008 09:08:40
I've been pulling a 60 for years, you wont have problem speeding and in low gear you wont run out of power. and have beat several 70s
utupuller
03-08-2008 04:57:37
Antique, stock???? I pulled a stock 70 for 2 years and never did much. We did not have the creeper gear. If I kept an inch of gas in the tank I could make 6500 class. I always liked how it ran but not down the track. My 2 cents is pull the one with the creeper gear.
