One More Thing
Buzzman72
03-13-2008 21:07:45
Might wanna make sure you "index" the hub and adapter so that the steering wheel is centered when the wheels are straight ahead. It'd be way too easy to make the adapter, and then find out it's not comfortable because it's not indexed properly.
I haven't made exactly that mistake before, but I've done similar things.
ChadS
03-14-2008 05:50:08
 Re: One More Thing in reply to Buzzman72, 03-13-2008 21:07:45
I had a grant GT wheel on my H, The hub idea works, but you do have to make a ring, that is bigger outside diameter,,, so you catch the three holes in the grant wheel. get a piece of aluminum bar, and whiddle ya one down, Use bigger bolts too,, mine kept comming loose and ended up welding it. I cut the nut down,,, (before I welded it)thinner and my horn button fit on there great!! ChadS ChadS3@hotmail.com
