TWO EXTREME JD
VA PULLER
03-17-2008 12:46:28
Just wondering how is a tube frame legal in NATPA Div 3&4 on a John Deere G ? Not trying to stir in anything.
Doug Boll
03-19-2008 08:11:04
 Re: TWO EXTREME JD in reply to VA PULLER, 03-17-2008 12:46:28
A billet crank would cost a good portion for what they want for a running tractor and it's already got one! Not a bad buy if you are into turn key pullers.
2 Extreme
03-17-2008 15:56:06
The original frame rails are inside the tube frame up to where they bolted on to the front pedistal. Pedistal is gone and replaced with a tube front end and rack and pinion steering
VA PULLER
03-17-2008 18:19:16
 Re: TWO EXTREME JD in reply to 2 Extreme, 03-17-2008 15:56:06
Thanks for the info just wondering.Very good looking tractor and very neat seen it pull in Tunica a couple years ago.
Not at that weight
03-17-2008 16:26:43
It's not going to weigh that light with stock framerails.. They are aluminum... How stock is that?
JDGnut
03-17-2008 18:03:39
 Re: TWO EXTREME JD in reply to Not at that weight, 03-17-2008 16:26:43
You can get to 4500.. We have two in our club that I pull against that are 4500.. One is using pressed steel in the back.. the other has AL rears.. Lots little tricks to lose weight... The builder of that tractor, knows all the tricks... I just got carried way with the welder.. and steel on mine.. and its a little over.. I could get there with some work.. but other things to work on first...
JDGnut
gpuller
03-17-2008 12:58:40
From what I've seen, it still does have the factory frame rails but has a tube axle ahead of the rails, its a combination of both.
for sale still?
03-17-2008 13:32:29
 Re: TWO EXTREME JD in reply to gpuller, 03-17-2008 12:58:40
will someone please buy that thing
can't afford
03-17-2008 20:51:26
 Re: TWO EXTREME JD in reply to for sale still?, 03-17-2008 13:32:29
I doubt anyone can afford it.
Drew
03-18-2008 15:36:35
 Re: TWO EXTREME JD in reply to can't afford, 03-17-2008 20:51:26
I know the price sounds high. Rest assured, you can't build one just like it for that kind of money.
