Which starter
1942 A
04-07-2008 11:57:32
I was wondering what people have had the best luck with. I have a big cube 1942 JD A, I need to get a gear reduction starter for it. Some people are using one from a bobcat skidsteer and one from a an 8000 series John Deere. I just want to know which one cranks the best.
Thanks
KJF470
04-08-2008 16:50:35
 Re: Which starter in reply to 1942 A, 04-07-2008 11:57:32
Hey Hot Rod, would you happen to have any photos of the starter bolted to the tractor for sale. And maybe a location and a price?
Hot Rod A
04-08-2008 20:03:00
 Re: Which starter in reply to KJF470, 04-08-2008 16:50:35
Yep, well a picture of the tractor anyways, I'd have to take a new picture of the starter itself...photo ads, ad # 209075.
Cabbage
04-09-2008 18:36:04
 Re: Which starter in reply to Hot Rod A, 04-08-2008 20:03:00
Hey hot rod did you have to put the starter up top or did it fit in the case? Nice lookin tractor!
Hot Rod A
04-09-2008 20:52:29
 Re: Which starter in reply to Cabbage, 04-09-2008 18:36:04
Put it on top--I'm not aware of any decent starter that mounts to the bottom of the case that has a long enough nose to grab the flywheel, let alone that'll have the solenoid in such a location to clear the inside of the case as well.
As far as I know, anyone who is using decent gear reduction or diesel starters are using top-mount bracketery or making their own.
Thanks for the compliment.
JDGnut
04-11-2008 15:39:15
 Re: Which starter in reply to Hot Rod A, 04-09-2008 20:52:29
I use the ones off the 8.1L JD engines.. it works good.. there are a few different starters.. really just a little different offset.. Not sure which one will work on the A.. but any from the Row Crop 30 series tractors and up will fit.. (Earlier will fit.. but not as good of a starter.) I don't remember what starter we have on the A...
JDGnut
Jim Johnson
04-07-2008 22:07:15
You can go to any good auto parts store and get a gear reduction starter that will work. Just take your old starter and match the gears up. Or call Phill at 765 922 4565 he will have it also.
Jim
Jim Johnson
04-07-2008 22:04:07
Jim
Ed Hodge
04-07-2008 18:08:56
acdelco 28mt i think that it will fit
Big Juggs
04-07-2008 12:43:21
Mine is over 600 cubes and I use the bobcat starter. Have to open petcocks. Very high compression.
1942 A
04-07-2008 13:06:53
 Re: Which starter in reply to Big Juggs, 04-07-2008 12:43:21
Mine will under yours, have you tried it with the petcocks closed?
Big Juggs
04-07-2008 14:15:48
 Re: Which starter in reply to 1942 A, 04-07-2008 13:06:53
Yes, and it's a "no go". My son has a 552 cube A with 9-1 comp. and his rolls over no problem with petcocks closed. Mine is 10.2-1 comp. The skidsteer starters will bolt right on. I am guessing they will work fine on yours.
1942 A
04-09-2008 12:07:23
 Re: Which starter in reply to Big Juggs, 04-07-2008 14:15:48
Thanks,
I was wondering how good they work, Do you know anyone using the one from the 8000 Series John Deere?
Thanks again
Hot Rod A
04-08-2008 01:28:48
I've got one of the bobcat starters Juggs referred to for sale...just gotta buy the rest of the tractor with it!
