POWER BOOSTER
770 Puller
04-08-2008 22:35:34
Was wondering if anyone out there new of some place that could beef up an Oliver power booster. running an open rpm class, know the IH guys build those torque amplifiers up was wondring about the same or if i should just take it off. any info would be appreciated
770Puller
04-12-2008 20:02:31
 Re: POWER BOOSTER in reply to 770 Puller, 04-08-2008 22:35:34
yeah, in the stock class it works great, key is not to shift to late, thats when they tend to over rev and blow thru the tires. can you give me more info on those overdrive units? never heard of this thanks
770
04-09-2008 17:33:28
Do you seriously pull better with a power booster? I've pulled my 770 for over 10 years and never lost to a 770, or 880 with a power booster. It always seems that in the instant of shifting, they would always loose traction. Anyways, I believe Brad from Maibach tractor in Ohio used to sell a heavier sprag for the units. maybe worth calling???
EFV
04-09-2008 04:27:32
Thought the trick there was to install the Gear Vendor overdive unit. Works great in Div. 4 and 5 tractors,should be even better in open rpm class.
