Restoration & Repair Tips Board
Allis Chalmers B Brakes
Orion Layman
03-26-2006 04:54:53
I am looking for information regarding how to replace my brake linings. Looking at the tractor, cannot imagine how they are removed and reinstalled without pulling the whole axle shaft casting.
russ1
03-29-2006 14:10:45
 Re: Allis Chalmers B Brakes in reply to Orion Layman, 03-26-2006 04:54:53
Orion, there are pins through the housing at the brake shoes that hold them in place. You will need remove those pins before you can get the shoes out. Pins are about 1/2 inch diameter.
JMS/MN
03-27-2006 22:04:48
Disconnect the linkage from the pedals. Remove the fenders and the angle iron they mount to. Disconnect the band from the linkage, pull it up and to the rear. Wouldn't hurt to attach a wire before pulling the old one out- use it to pull the new one in.
wgm
03-26-2006 06:07:49
Orion,
It"s fairly easy to change the bands. If I remember correctly I used a piece of wire tied to one end of the band to pull it through.
