Restoration & Repair Tips Board
Head Torque
Joel Watkins
04-02-2006 20:26:23
Does anyone know what the head bolt torque is for a 3020 with a 270 diesel? Also need rod bolt torque and valve clearences.
msb
04-03-2006 20:06:19
 Re: Head Torque in reply to Joel Watkins, 04-02-2006 20:26:23
Depends on which head bolts you are using.If you are using the latest which I would use,you can go up to 150 ft.lb.;Rod bolts 120-130 ft.lb.;valve clearance--.018 intake --.018 exhaust.
