Restoration & Repair Tips Board
possible hydraulic lift problem
gary sol
04-03-2006 08:02:23
Hi, iam a newbee to tractors and I was looking at purchasing a 53 ford golden jubilee. the owner let me use it to see if i liked it and it worked flawless all weekend except for last last few minutes. I brushhoged all weekend and it worked great but when i was about to unhook the 6ft brushhog the hydrraulic would not go up or/down for about 1 minute . seemed like the lever was very free to move up and down and heard a slight wineing noise. i raised the rpms a little and everything started to work again .Is this a sign of trouble to be coming ? I would value anyones opinion? thanks
souNdguy
04-03-2006 12:24:54
 Re: possible hydraulic lift problem in reply to gary sol, 04-03-2006 08:02:23
Lets see.. could have been a stuck unloading valve ( dirt / trash / bad oil ).. or could have been a lossof prime due to a leak on the intake/shaft seal of the pump.
Soundguy
old
04-03-2006 09:07:01
May have a valve that is sticking and or water in the system. Or it could also be a bigger problem real hard to tell with out opening it up and looking at things
