Restoration & Repair Tips Board
Oversize piston rings
billybunter
04-04-2006 12:39:06
Hi
I have a Massey 97 low on compression due I guess to worn cylinders. This tractor will only be used lightly and for going to local shows.Assuming standard bores at present can I hone these and fit 60+ rings.I plan to re-gap the ring ends when placed at the bottom of the cylinders (the unworn part).Will thses help take the wear or will they not fit the cylinder dia? If I were to re-gap the ends what clearance should I create?
Thanks for now.
jdemaris
04-06-2006 06:17:40
 Re: Oversize piston rings in reply to billybunter, 04-04-2006 12:39:06
If done right, it will work fine. We used to rebuild pistons - recut the grooves to oversize, knurl the skirts, etc. Then parts got cheap, and labor expensive, and it wasn't worth it anymore. Now ?? It is just as important to repair the side clearance, i.e. the ring-grooves on the pistons. It is just as important if not more than the ring-diameter and end-gap. Check if with a feeler gauge. Hasting sells repair shims and they are cheap. Requires having someone recut the ring grooves in the pistons. I just had four pistons cut and it cost me $30 total. I don't know why you picked the .060" oversize number - you should stick as close as possible to the original. If standard bore now, and worn, trying getting some .002" oversize, or .010". I've installed slightly oversize rings on many tractors and it worked fine. I wouldn't do it on a diesel, and I wouldn't do it on a machine I was working every day. Hastings will sell you individual rings which is a pretty good deal. So, you can pick and choose.
Bob
04-04-2006 20:34:41
Here's a link to one expert's opinion on fitting rings:
