Restoration & Repair Tips Board
JD4020 wont run
Scott Rebault
04-09-2006 14:28:29
I have a '70 4020 deisel and it will start and run for a couple of seconds, but will not stay running. I have drained the fuel tank and replaced with fresh fuel, replaced the fuel filter, and primed thru the injector pump. Also have installed new air filter. It has a Roosa Master injector pump. Any ideas, I'm fresh out...
msb
04-09-2006 19:55:15
 Re: JD4020 wont run in reply to Scott Rebault, 04-09-2006 14:28:29
Is it a CB model pump or a DB model? Need to know before we can help you.
Scott Tebault
04-10-2006 06:23:00
 Re: JD4020 wont run in reply to msb, 04-09-2006 19:55:15
I do not know. The pump is apparently driven much like a distributor and sits verticaly. The numbers from the placard are as follows:
SN JDB 633AL2404
MD 1425873
MF AR-50147
Thanks for your help.
msb
04-10-2006 20:11:28
 Re: JD4020 wont run in reply to Scott Tebault, 04-10-2006 06:23:00
Its a DB pump.Sounds like the pump needs rebuilt.
