Restoration & Repair Tips Board
Standard pistons W/oversize rings
Bob Underwood
04-12-2006 04:17:38
I have a49 Farmall Cub the cylinders are worn from .007 to .010 at the top. The middle and lower are worn within the .025 the book allows for. The pistons are worn quite a bit. Sence the new oversize flat top pistons start at .020 would it be a good or bad idea to use new standard pistons with .020 oversize rings. Thanks for any reply Bob
george md
04-12-2006 14:30:39
 Re: Standard pistons W/oversize rings in reply to Bob Underwood, 04-12-2006 04:17:38
Bob,
The .0025 wear you have at the bottom is within
limits for std rings, If you fit a set of rings to
the worn part of the cylinder , there is not enough ring gap to absorb the change when the
piston goes to the bottom of the cyl. Things will
come to a screeching halt . Also with a cyl that
is worn .010 , it may or may not bore clean at
.020 as cylinders don't wear concentric.
Bore it , the cast iron pistons are not too
expensive but if you want the aluminium ones for the cub low boy to perk it up a little it's going to hurt .
george
Bob Underwood
04-13-2006 04:15:56
 Re: Standard pistons W/oversize rings in reply to george md, 04-12-2006 14:30:39
Thanks for the replys. I would have put the aluminum pistons in but they have a dome and I would need another head or mill mine and I have no idea how much should come out. I am not trying to do a cheap job just didn't want to remove engine at this time. Bob
george md
04-13-2006 07:05:18
 Re: Standard pistons W/oversize rings in reply to Bob Underwood, 04-13-2006 04:15:56
Bob, The aluminum pistons will clear the head with out any modifications , I did one recently .
george
Bob Underwood
04-13-2006 16:56:43
 Re: Standard pistons W/oversize rings in reply to george md, 04-13-2006 07:05:18
Thanks George. I was told by CIH the dome pistons would not clear. I will go that route less weight moving around. Bob
muggsw6
04-12-2006 07:39:26
Bob, you either need to bore your block .020 and use new .020 pistons & rings or hone your block and roll the dice with new std. rings. I would not mix sizes. If money is not of major consideration, just bore it and it will be good for a good long while. my 2 centavos Mark
