Restoration & Repair Tips Board
F 14 engine stuck
Steel Horse Fa
04-19-2006 20:10:42
I have an F14 that ran about 2 years ago and I try to either start all of my tractors or at least turn them over before winter sets in and in the spring time. I got behind on doing this and now the F14 and my Case VAC are now stuck. I noticed when I cranked the F14 over it went about a half a turn of the crank and that was it I tried to pull it forward and reverse and can't seem to brake it loose. I have put penetrating fluids in the cylinders and let it soak for about 3 months and still STUCK. I would hate to start pulling pans and heads off but I may have to. thanks for any ideas.
jason(ma)
04-23-2006 05:15:07
 Re: F 14 engine stuck in reply to Steel Horse Farms, 04-19-2006 20:10:42
have you checked the clutch? Mice may have something jammed in there. It's a long shot but easier than than pulling a head.
Steel horse farms
04-23-2006 07:05:10
 Re: F 14 engine stuck in reply to jason(ma), 04-23-2006 05:15:07
Jason,
I have not checked the clutch, But when I pull it I will let the clutch in and out. When the clutch is in it rolls free,when the clutch is let out of coarse the wheels just slide
old
04-19-2006 20:58:15
What have you put in the cylinders?? I will only use tranny fluid and or a mix of tranny fluid and turpentine. So far I have had only one engine that hasn't popped free doing this and thats out of say 20 plus engines
terdybukrat
04-24-2006 15:38:48
 Re: F 14 engine stuck in reply to old, 04-19-2006 20:58:15
I would love to see your recipe/formula for stuck engines that SteelHorseFarm mentions. I have a Farmall 100 with a stuck engine.
Thanks
Terry B
old
04-24-2006 16:04:09
 Re: F 14 engine stuck in reply to terdybukrat, 04-24-2006 15:38:48
All I use is a 50/50 mix of turpentine and tranny fluid. Fill the cylinders put the plugs back in and walk away for a few days. Top it off every few days and also every few days hit the starter button of course make sure it has a good battery.Watch the crank pulley when you hit the starter button, if it mores any then pull the plugs and keep hitting the button with quick hits
terdybukrat
04-29-2006 19:38:12
 Re: F 14 engine stuck in reply to old, 04-24-2006 16:04:09
I will give it a try. Thank you.
Terry B
Steel horse farms
04-20-2006 04:16:28
hobby farm,
thanks for the formula,I used PB penetrating catalyst which does a great job of loosening bolts and nuts. I also used diesel fuel.how long did you let that set?
old
04-20-2006 07:40:39
 Re: F 14 engine stuck in reply to Steel horse farms, 04-20-2006 04:16:28
That all depended on which ones. I have had them pop loose after just a few hours and the others took a month or so. I've got an H that I did that to and it was llose in about 4 hours and it now purrs like a kitten. But I also have a MH-30 that had to sit for a month and its now loose but when it popped loose one valve broke. I have way to many tractors by the way, something like 30 of them and a few are pictured in the web site
