Oliver 88 Restoration
Eric Kramer
03-03-2002 09:13:13
I have a 1949 Oliver 88 that I am currently trying to restore. I have taken several parts off of it. It's now down to the engine still on the frame. I need help on what to do next. Should I pull the engine and start on that first? I plan on having it sandblasted, but I would like to know how I could remove most of the rust myself on littler parts such as the seat.
Jeff Oliver
03-11-2002 21:54:04
 Re: Oliver 88 Restoration in reply to Eric Kramer, 03-03-2002 09:13:13
Unless you just want to have the frame and engine bead blasted you might try soaking it all in oven cleaner really good then using a high pressure washer. If you have never tried this you would be amazed at how much it will take off. Also if you can find a place that sells commercial strength degreasers they will work good too. Some will strip paint even and most now are citrus based which makes it alot nicer to work with.
I have an 88 also that I will be doing a restoration to probably this coming winter. Let us know how it goes!
Greg
03-07-2002 09:19:07
For cleaning small parts, a bead blast cabinet is really nice. Sometimes, a machine shop can do the job, or, if you have a large enough compressor, you can rent one. New bead blast cabinets are $300-$3500 depending on size. They utilize fiberglas beads for a cleaning medium. Good luck and all the best..... ...Greg
