Restoration & Repair Tips Board
How do you check JD A RPM?
Mark Wengert
04-22-2006 19:16:19
I just bought a 1945 JD A. Hand start with wico X mag. It sounds like it is not running fast enough. There is not a great difference form idle to wide open. My '52 A that I used to own sounded like it turned a much higher RPM than this one does. How do I check it? Do I need to buy a tool? And what is the wide open RPM suppose to be?
Thanks for all and any help.
Mark
Burlington Flats, NY
jdemaris
05-03-2006 12:28:31
 Re: How do you check JD A RPM? in reply to Mark Wengert, 04-22-2006 19:16:19
The hand-held tachs work nice if you have access to one. We used to use the little AC Delco tachs at our dealership back when they cost $15 each. A vibration tach will probably also work and they are cheap - still only around $5. We used them mostly on chain-saws and lawn-mowers, but as I recall, they also worked okay on the two-cylinder farm tractors. If you get stuck, I don't live too far from you - I'm in Worcester, Otsego County, NY. I could lend you what you need.
Pappy
04-24-2006 21:38:19
I have one of those old Sears Engine analyzers with built in tachometer. It can be set for four cylinder operation and works great on a John Deere.
Glen in TX
04-24-2006 12:02:25
Measure in the center of crankshaft with a hand held mechanical tachometer. Electronic ones will have reflective tape to put on crank or flywheel.
RPM Dial Tachometer • Range: 0 to 4000 rpm • Accuracy: ±3% Get fast rpm readings. This contact tachometer includes one cone and one concave tip. It has a 2 3/4" dial face with a glass cover. Housing is steel. Size is 2 3/4" Dia. x 4" Lg. Optional 12" extension shaft gets into hard-to-reach areas. Each Tachometer 1416T1 $61.73 12" Extension Shaft 1416T2 21.20 Per Set Replacement Tips (One Cone, One Concave) 1416T3 $4.82
greenmech
04-22-2006 20:16:00
An RPM hand held meter. Set speed at 1080 RPM at no load and 975 under load. Ron Mn.
