Restoration & Repair Tips Board
Cleaning out air filter
wdtom
04-23-2006 17:44:03
I am trying to clean out the built up oil and dirt that is inside the air filter on the Allis Chalmers WD I am working on. The filter hasn't been used in years, and the space where the air comes down from the air intake on top to the oil bath is partly plugged with dryed dirt and oil. I have got a long screwdriver down in there and got most of it out, probably OK, but would like to get it clean, does anyone know of a good way to get this stuff out? The space is only about 1/4" wide and it is difficult to even see in there, never mind work and tell if it is really clean. Spray on engine cleaner? Gas?
lonzoll
12-09-2006 19:31:13
 Re: Cleaning out air filter in reply to wdtom, 04-23-2006 17:44:03
i use drain cleaner and lots of it in a 5 gallon bucket of water and use the strongest dish soap you can find, let is soak 2 or 3 days and remove and wash with water and may need a little more soaking to finish the job.don't use gas it can cause you to be sent to the burn unit, take your shop,or life, and anything else that will burn, Vingar will kill drain cleaner so keep a bottle around, that stuff won't burn the house down and it smells better,
wdtom
04-25-2006 17:36:18
Thanks, that's about what I figured would work best. Will get to it this weekend.
old
04-23-2006 18:42:13
I'd drop in in a pan of gas, I'd say kero but shoot gas is cheaper and will also do the trick.
RustyFarmall
04-24-2006 04:26:38
 Re: Cleaning out air filter in reply to old, 04-23-2006 18:42:13
Indeed, gas is less expensive, but gasoline will evaporate too quickly. I would use diesel fuel, just set the air cleaner assemblt down into a 5 gallon bucket, fill the bucket with diesel fuel, and let it soak for awhile, maybe a few days. Slosh it up and down in the fuel from time to time, and then pull it out, set it somewhere and let it drip till it's dry.
old
04-24-2006 08:20:56
 Re: Cleaning out air filter in reply to RustyFarmall, 04-24-2006 04:26:38
Hey rusty if it fit in a 5 gallion bucket and he puts a lid on it the gas will stay there also. Gas stays if its sealed up LOL
