Restoration & Repair Tips Board
Farmall H with LPG
danimal2
04-26-2006 15:41:31
Hello Everyone. This is my first time to post as well as my first Farmall (project). I have just brought home a 1943 Farmall H and it was converted to LPG. It has a Ensign system on it and I know nothing about them. What is apparent to me though is that the regulator has two connections that are open. The gas connections are there and appear to be correct, but I do not know what the other two are for or how to hook them up.
The previous owner stated that it did run just a couple of months ago, but would need the water hooked back up to the regulator. Not sure where these connections go. Also, this is suppose to be a 6v positive ground system and the PO had a 12V battery hooked up to it as a positive ground. Will there be any complications with that.
Thank you in advance for all of your help with this question as well as the many I may have in the next couple of weeks.
I will be purchasing a manual for the tractor tonight online.
Thank you,
Daniel Biddix
San Angelo, TX
