B Allis ammeter wiring directions?
Ronnie H.
03-03-2002 20:29:58
I recently bought a 47 B Allis that has been changed to 12 volt, and the ammeter is not working. I replaced it and it still does not work. After closer examination I don't think it is wired correctly. Can anyone help me find the proper diagram? Thanks
Ronnie H.
03-06-2002 15:56:54
 Re: B Allis ammeter wiring directions? in reply to Ronnie H., 03-03-2002 20:29:58
Thanks Steve, I'll give the alternator option a try.
steve
03-06-2002 10:49:46
If you hav an alternator, the big terminal on the alternator (bat) goes to the ampmeter and the other terminal on the ampmeter goes to the + terminal on the battery (or battery cable at the starter). If you have a 12 volt generator, the A terminal on the generator goes to the A or G terminal on the voltage regulator. The "B" terminal on the voltage regulator goes to the amp meter, and the other side goes boack to the battery. The amp meter is always between the battery and the charging units voltage regulator. What are you using to charge, generator or alternator. If a generator, is the battery neg or pos ground.
