Restoration & Repair Tips Board
Ya Hoooo!! I got it!!
D'Marie
04-27-2006 20:39:04
I'm so excited! I got the mower deck back on!! Thank you, thank you, thank you!! I wasn't sure about getting the belt back on, so I took the spark plug out (for safety reasons), put the belt on as far as I could, and than slowly turned the wheel. And, it too, worked! Next, I put the spark plug back in, put the hood on, started the engine, and hit the switch to turn the mower on... everything is working! Do I sound excited? :-) (Blush) Now I can't wait for tomorrow morning to get here so I can get back to work and get my grass mowed. Seriously, thank you so much for your help.
paul in on
04-27-2006 20:52:10
 Re: Ya Hoooo!! I got it!! in reply to D'Marie, 04-27-2006 20:39:04
Not a problem. Smart thinking when it came to taking the spark plug off. We usually take our deck off bedire we winterize ours and clean it real well. Anyway, happy cutting, What size of deck do u have for 2 acres? Paul
D'Marie
04-28-2006 14:59:29
 Re: Ya Hoooo!! I got it!! in reply to paul in on, 04-27-2006 20:52:10
Paul, I'm not sure what size the deck is, so I measured it from side to side. It's about 45" and has 3 blades underneath. I hope you don't mind me asking, but what steps do you take to winterize your's? Also, how often should one have the blades sharpened? And lastly, should I "wash and wax" it just like a car (for upkeep/appearance), or just wipe it down occasionally? Again, thanks Paul.
Paul in On
05-02-2006 19:09:17
 Winterizing your mower in reply to D'Marie, 04-28-2006 14:59:29
Been gone for a week so just got around to this. Take out the battery and fully charge it before the winter. I leave it out of the machine too, no difference. I just take some armerall and wipe it down. If you want to go that extra mile, knock yourself out. Depending on what type of blades you have, the grade of steel, what you cut (lots of sand or fine dirt) all affect how sharp the blade is. As long as there seems to be an edge that is fairly sharp, and smooth, then they'll be okay. By smooth I mean no rock chunks taken out of it. Take a file, not a grinder, and file with a file as it won't take the temper out of the blades and they last longer. With a grinder the blades heat up aqnd it takes the tmeper out of them, making them chip easier. I do mine at least once a year for sure. I also change oil and filter before putting it away so it's ready to go in the spring. Make sure you give each grease nipple two shotys fo grease and make sure every nut and bolt is tight. That;s all I think. Paul
