Restoration & Repair Tips Board
Farmall H will not start
Danimal2
05-03-2006 15:38:24
Hello Everyone, This is my second time to post a question.
I am having problems getting spark to my tractor. It has a magneto setup as well as a LPG tank. Just had the LPG filled and it turns over, but no spark. I just replaced the cap and plug wires and nothing. How do you check a magneto and how do you start a tractor that has a magneto. This tractor had a 12V battery hooked up to it with a starter switch and a kill switch. I charged the battery and it turns over great (positive ground).
Any and all help would be great.
Thank you,
Daniel
San Angelo, TX
old
05-03-2006 17:49:29
 Re: Farmall H will not start in reply to Danimal2, 05-03-2006 15:38:24
Most of the time if a mag doesn't have spark, it means the points need to be cleaned and or replaced. Or your kill switch has gone bad
Danimal2
05-04-2006 05:28:53
 Re: Farmall H will not start in reply to old, 05-03-2006 17:49:29
Thank you for your reply. I will go to Tractor Supply and see if they have a set of points and condensor. It may have to be ordered, as they do not stock a lot of the older parts. Kill switch can be disconneted to see if that is he problem (is this correct) as long as the wire is not grounded.
Thank you again,
Daniel
old
05-04-2006 07:37:02
 Re: Farmall H will not start in reply to Danimal2, 05-04-2006 05:28:53
Yep kill switch can be unhooked to see if thats the problem. You also have to make sure you ask for points for a mag since they are differant then the points for a distubutor
Danimal2
05-04-2006 16:50:54
 Re: Farmall H will not start in reply to old, 05-04-2006 07:37:02
Thank you again for your reply. Do I need to remove the Magneto from the tractor or is most of this accessible from the tractor. I have done points and condensor on cars (been a few years) so I think I can handle this. I purchased a tune up kit from Tractor Supply for the H-4 Magneto ignition. Hope to get it done in the next day or so. I have a short on the starter now, but should be an easy fix. The starter is grounding out at the connection from the battery.
Thank you so much for your replys. I had posted one earlier last week and did not get anything, but I think I am making progress. Would really like to convert back to gas at some time, but finding that can be expensive.
Daniel
old
05-04-2006 17:04:23
 Re: Farmall H will not start in reply to Danimal2, 05-04-2006 16:50:54
Should be able to do it right on the tractor but it may be just a little tricky doing so. Not sure on that mag if you have a problem whith retimeing it or not. Some of them you do some you don't and I don't know much about that mag.
Danimal2
05-04-2006 17:08:40
 Re: Farmall H will not start in reply to old, 05-04-2006 17:04:23
Thank you all the same. You have been a great help and have help to ease my mind as well as getting the wife to understand.
Thanks,
Daniel
old
05-04-2006 17:18:53
 Re: Farmall H will not start in reply to Danimal2, 05-04-2006 17:08:40
You most only have one tractor. I have so many of them that if they all ran I could drive one each day of the month and never drive the same one till the next month. At times it can be fun just keeping the ones that run, running.
