Restoration & Repair Tips Board
timing gears
dschrems
05-03-2006 16:21:31
just recently put new timing gears in my perkins desiel. now it won,t start. it sounds like there is air comimg out of the air cleaner when you crank it over. it also doesn,t seemlike it i9s getting fuel . i have fuel to the injector put but it will not pump it to the injeectors . the least bit of starting fluid and it locks up. any ideas?
ricedaddy
05-04-2006 08:58:34
 Re: timing gears in reply to dschrems, 05-03-2006 16:21:31
sounds as tho it's timed 180 degrees out
JMS/MN
05-04-2006 08:18:04
Timing gears could be off by 180 degrees. Does it suck air at the exhaust pipe? Some engines have two marks on the gears, and you need to use the right combo.
