Restoration & Repair Tips Board
Hydraulic cylinder problem IH 1190 Haybine
Green Hay Compa
05-11-2006 05:47:11
I have a IH model 1190 haybine that only lifts on one side. I believe the bad side is a cylinder that may have failed internally as there is no sign of fluid leakage. Seems impossible to get at that cylinder, anyone have suggestions? Would air in the line cause that problem?? I just got the haybine and it did work properly a couple of times then failed.
thanks,
gb
