Restoration & Repair Tips Board
Ford 860
Justin Geen
05-14-2006 13:15:59
My 860 starts fine, and runs well at low throttle. But when the throttle is turned up, or the engine put under any strain, like moving, the engine cuts out. I replaced the fuel filter and rebuilt the carb with a kit. Don't know where to go from here, any suggestions?
souNdguy
05-14-2006 15:43:51
 Re: Ford 860 in reply to Justin Geen, 05-14-2006 13:15:59
Fire order correct?
Good blue spark?
Good compresion?
Plenty of fuel in the carb bowl if you check the drain?
Main needle rich enough and not clogged?
Stumbling or hesitation when you goose the throttle is a sign of a plugged main needle/jet, or too lean a setting.. or a fuel obstruction. Old's got it right.
Soundguy
old
05-14-2006 15:05:14
Does chokeing it help any?? If it does then you missed some junk in the carb which is easy to do.
