Restoration & Repair Tips Board
Iron or Steel
IronHorse
05-16-2006 06:13:17
How can I tell If the metal is Cast Iron or Steel?
I need to make a repair and need to know if I can weld or need to just plate it?
thanks
Pete7
05-21-2006 09:08:07
 Re: Iron or Steel in reply to IronHorse, 05-16-2006 06:13:17
Another way to tell...drill a hole in it. Cast iron produces a powder and steel produces you a curl or shavings.
Don-Wi
05-21-2006 07:48:49
Do a spark test. Compare the sparks to known steel and known cast. They give off 2 very different spark patterns.
Donovan from Wisconsin
