Restoration & Repair Tips Board
2N tractor will not start
Joe Agey
05-16-2006 15:33:19
I have a 1947 2N that will fire one or two time but it will not run at all I have replace the wires on it and have check the compression on all the cylinders and there is 120psi on all cylinders have replace the condenser and rebuild the carburetor and have clean the air filter and still will not run can any one help think joe
old
05-16-2006 17:01:56
 Re: 2N tractor will not start in reply to Joe Agey, 05-16-2006 15:33:19
Are you sure it has spark?? And if it has spark is it a nice brite blue spark or is it sort of a weak yellow spark?? Also have you pulled the plugs back out to see it they are wet?? If they are then they have fuel fouled on you and you need to clean/dry them
Joe Agey
05-22-2006 14:00:40
 Re: 2N tractor will not start in reply to old, 05-16-2006 17:01:56
Have fix the tractor it was the plugs. Thanks for the help Joe
joe agey
05-20-2006 14:37:04
I have a good blue spark on the secondary side of the coil and I have spark at all the spark plugs. The point gap is set at .025 thousandths.it still won"t crank up.
old
05-20-2006 15:47:44
 Re: 2N tractor will not start in reply to joe agey, 05-20-2006 14:37:04
Hers some thing to try, pull the air intake tube off the carb and hold your hand over the air intake and crank the engine. It should suck on your hand, if it doesn't you may have a problem with low compression and if you have that problem put about a table spoon of oil in each cylinder and try to start it again.
Rustyj14
05-19-2006 15:59:37
Hey, Old, neat essay on your farm and operations. And the thing about a horse's feelings, is great,too. My Mother's folks had a farm near Evans city, PA., north of Pittsburgh, PA., back when i was a young feller. I'd go there in the summer, until i left for the Army. What wonderful days and weeks! but, it wasn't all play-no, i had to work, too! I learned a lot-about horses, cows, all kinds of animals. And, about life and death, too. Best day every summer was when the"thrashers" came! And, Grandma, my mother, and her sisters would lay out a spread of food and desserts big enough to feed half the county! and, we did away with most of it! My uncle Vern would entertain us kids with a story about a big white ghost of an old horse that ran across the ridge south of the farm, mostly in the moon-light! We set out many a night in summer, watching for that horse to show, but we never saw it! My younger brother had the chore of bringing in the cows from pasture, in the late afternoon! His favorite trick was to grab a cowtail, and get pulled back to the barn. One day, Old Bossy got riled up, took off at high speed, and brother's feet hit the ground every 5-6 feet or so! And after being dragged a long way on his knees, i think he got the message! He never did that again!
Rustyj
Stan(PA)
05-20-2006 07:55:27
 Re: 2N tractor will not start in reply to Rustyj14, 05-19-2006 15:59:37
Hey Rusty, I"m about 100 miles north of Evans City. Do you still live in that area? ...Stan
old
05-19-2006 20:44:33
Thanks, the web site is my wifes thing and she just puts the tractors in to please me sort of I guess. The animals are her thing and the tractors are my thing.
