Restoration & Repair Tips Board
1944 Ford 2N dont start
Syl
05-21-2006 18:02:57
before the tractor ran good but after couple day, it never start, little noise in front i dont no to do! Is it main bearing! please help me
Joe Agey
05-22-2006 19:37:58
 Re: 1944 Ford 2N dont start in reply to Syl, 05-21-2006 18:02:57
I have a 1947 2n that was running then two days later it would not fire up at all. It would fire one or two times but would not start. I had replaced the condensor,took the points out and cleaned them and rebuilt the carburator cleaned the air filter took the plugs out cleaned the plugs and it sill would not run so I bought some new plugs and put them in and it fired right up. Joe
Syl
05-22-2006 12:43:15
the motor not die after running , but the motor is not strong and when i start it very difficult,6 volts
souNdguy
05-22-2006 12:55:19
 Re: 1944 Ford 2N dont start in reply to Syl, 05-22-2006 12:43:15
Hows the spark look? What's oil pressure like? is it charging good?
The more info you give us.. the better we can help you. These 2 line messagesou leave where you just stingyly dribble the info to us is making it HARD for us to help you... especially when you reply to your own message.. and not our message.. so that we don't know there is a reply!!
Soundguy
souNdguy
05-22-2006 06:38:41
When it was running.. what was the OP like? Did it die while running.. or won't start after you shut her down?
Does it crank over but not start.. or not crank over?
Soundguy
Syl
05-25-2006 20:03:27
 Re: 1944 Ford 2N dont start in reply to souNdguy, 05-22-2006 06:38:41
it crank over but not start, i gone check the spark and pressure oil... what you mean the OP Syl
souNdguy
05-25-2006 20:32:25
 Re: 1944 Ford 2N dont start in reply to Syl, 05-25-2006 20:03:27
OP Oil Pressure
Soundguy
