430/441 case head
doc-x
10-20-2001 22:59:21
i need info on torque specs and tightening sequence for a 430/441 case cylinder head, any info would be a big help. thanks!!!!!
D13
10-21-2001 04:46:53
 Re: 430/441 case head in reply to doc-x, 10-20-2001 22:59:21
Gas or Diesel?
Per Intertec:
gas: there are 5 bolts on 1 side, 9 on the other. Standing on the 9 bolt side, number the 9 bolts from left to right: 13, 9, 7, 3, 1, 4, 8, 10, 14. Still standing on the 9 bolt side, number the 5 bolts from left to right: 11, 2, 2, 6, 12. Tighten in number sequence. 95-100 ft-lb. Manifold and rocker arm brackets 30 ft-lb.
Diesel: there is one row with 9 bolts outside the valve cover and a double row, each with 5 bolts, inside. Standing at the 9 bolt side, left to right on the 9 bolt outside row : 17, 12, 8, 7, 3, 6, 9, 13, 14. Of these, the first one is next to the valve cover, then next one is away, etc. On the double row, left to right, still standing on the 9 bolt side. The inner row (closest to the center of the head) : 18, 5, 4, 15. The outer row (next to the valve cover gasket rail): 19, 11, 1, 10, 16. Torque is 95-100 ft-lb. Timing hear housing to cylinder head - 4 bolts, 25-30 ft-lb
injector stud nuts 12-15 ft-lb
water pump 20-25 ft-lb
injector lines 20ft-lb
Others as above.
I'm not looking forward to rebuilding my 430 diesel. Thank heaven it's the wife's tractor and she'll probably insist on a REAL mechanic.
