Restoration & Repair Tips Board
restoring old hay rake
djmg
05-24-2006 18:55:20
I was given permission to pull from the woods an old hay rake off my mother in laws 40 acres. I believe it is horse drawn. I just love it. I want to restore it but a few problems, I dont how. of course it very rusty and hasnt any paint left. I need direction. I would also like to find out what kind it is. I have been all over it and found no markings. Please someone help me
thanks
dona
OLEN
06-07-2006 10:23:36
 Re: restoring old hay rake in reply to djmg, 05-24-2006 18:55:20
DONA,LOOK UP A PRODUCT CALLED EVAPO-RUST.COM AND DO SOME RESEARCH, I HAVE DONE SOME WORK WITH THIS PRODUCTS. I HAVE SOME PICS IF YOU WANT TO E-MAIL ME AND I'LL SEND TO YA,GOOD LUCK
dave66
05-25-2006 10:42:58
I have a old horse drawn rake also and the seat has Walter A.Wood stamped in it.Anyone have any idea what brand this rake might be?
DCM
06-07-2006 11:37:29
 Re: restoring old hay rake in reply to dave66, 05-25-2006 10:42:58
Have Dad"s old Frost+Wood horse drawn hay mower, maybe there is a connection there.Dan in Alberta
RustyFarmall
05-25-2006 08:12:58
Get yourself a couple of stiff wire brushes and go to work. A little soap and water will help some also, but use sparingly. Quite often the brushing will reveal things that you didn't know were there, you might even find a manufacturers mark which quite often was molded or stamped right into the steel as it was being formed. You might even get lucky and find traces of the original paint, particularly on the underside where the sun hasn't been able to bake it off. You don't need to get the steel cleaned right down to the point that it looks like new steel, just get it as clean as possible and then go to your local farm store, buy some implement enamel that is at least close to the color you need, get some paint thinner that is compatible with the paint you are using, and while there pick up a few good quality paint brushes. Yes, I said brushes, there is no need for any high tech paint spraying equipment on something like an old hay rake. Have fun, an old hay rake is a great way to learn a few things, and if you don't like what you have done, you can do it over and still not have a lot of money involved.
jubilee johnny
05-25-2006 04:58:52
I have an old horse drawn jd plow/lister that I restored and is in the front lawn as yard art. I believe the best way to restore rusted items like that is to sand blast them. The metal on mine really cleaned up good right down to the bare metal. If you don't have a sandblaster find out who does that kind of work in your area and get a price. Then prime and paint it. It might even show its identity after the rust is gone. Mine has john deere stamped in the metal. good luck
