Restoration & Repair Tips Board
8N starting problem
Brandon Sagrill
06-07-2006 16:24:44
I have a 48 8n that was running fine and then quit. I have plenty of gas but no spark at the plugs whatsoever. I have replaced the distributor cap, coil, plugs, points, and condensor. Not a thing has helped. I still have no spark at the plugs. Please help.
noncompos
06-10-2006 20:04:00
 Re: 8N starting problem in reply to Brandon Sagrillo, 06-07-2006 16:24:44
If you"re still not running, watch the rotor while someone cranks it, to make sure it"s turning; if not, you"ve stripped the dist gear or broke the dist shaft. They can stick and feel solid but not be turning. Good luck.
old
06-07-2006 18:12:36
Do you have power at the top of the coil?? You may have a bad ignition switch or a wire has burned in 2
Brandon Sagrillo
06-08-2006 08:10:00
 Re: 8N starting problem in reply to old, 06-07-2006 18:12:36
I do have power to the top of the coil. The wire seems to check out fine.
old
06-08-2006 09:58:06
 Re: 8N starting problem in reply to Brandon Sagrillo, 06-08-2006 08:10:00
You may have a bad coil or when you put in the new point/condenser you may have shorted out a wire in the distubutor. Its very easy to short or the wire from the condenser to the points
WvaJim
06-10-2006 23:48:22
 Re: 8N starting problem in reply to old, 06-08-2006 09:58:06
Recently run into a non starting non sparking 8N that turned out to have bad insulator on the breaker plate in the distributer, where the points and condensor screw is. New breaker plate and runs fine.
Brandon Sagrillo
06-12-2006 13:17:16
 Re: 8N starting problem in reply to WvaJim, 06-10-2006 23:48:22
Finally got it running. Only thing I can figure out is that it was the condenser grounding itself out. Thanks for the help. I wouldn't have got it without you all.
