Restoration & Repair Tips Board
Leaking cap screw
ol' guy
06-10-2006 08:46:02
I've prepared a '49 "A" JD for the final coat of painting, and now grease is seeping out around one of the cap screws that secures the transmission cover. A friend suggestes that I remove the cap screw, clean it thoroughly and cover it with gasket cement. My question is: what gasket sealant?? The black Permatex, the blue stuff or the clear, or what????
Thanks for the help.
souNdguy
06-10-2006 21:44:45
 Re: Leaking cap screw in reply to ol' guy, 06-10-2006 08:46:02
This sounds just like a nuisance capilary leak.. not a pressurized sump / critical leak. I'd pull and clean the bolt, and hole, and then hit the threads with whatever (curing) permatex or rtv you have on hand, reinstall the bolt, and wip up the mess... let cure, and be about your business.
Soundguy
