Restoration & Repair Tips Board
Ford 3000 Steering
Blluther
06-10-2006 10:44:29
Out in the field running my disc. Raised the disc up and started to make a left hand turn. No turn. After spinning the wheel, it did turn right. Had to push on the left control arm with my foot to get it to slightly turn. Finally got it back in to the barn.
When I turn the wheel to the left, the steering wheel acts as if it is unthreading. Before I go and start unbolting everything, thought I"d ask the question to the pros.
Let me know.....
Bill
souNdguy
06-10-2006 21:49:15
 Re: Ford 3000 Steering in reply to Blluther, 06-10-2006 10:44:29
Thrust bearing most likely..
Soundguy
Hurryin_Hoosier
06-10-2006 13:07:02
Look at this previous thread from the Ford board. If you need more, post your question on that board and you will probably get replies from those that have been there before.
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=ford&th=22943
