Restoration & Repair Tips Board
3010 Power steering fluid leak
Justin Jagiella
06-15-2006 13:15:07
I have a 3010 diesel that is leaking hydraulic fluid profusely from somewhere in the steering column...any ideas? It looks like a real job to get at. I took the cowl off and still can't see where it's coming from. Is this uncommon? Has anyone had to fix this before? Thanks, Justin
msb
06-15-2006 21:48:14
 Re: 3010 Power steering fluid leak in reply to Justin Jagiella, 06-15-2006 13:15:07
If its coming out the top of the steering shaft the the valve will have to be removed and rebuilt.Not a job for an amateur.Have someone rebuild it that is trained to do so.
