Restoration & Repair Tips Board
Ford 5000 Lights
robert wood
06-17-2006 15:49:50
While driving down the road on my 1968 Ford 5000 all the lights went out: headlights, flashers, spot. Checked the fuse and it looked OK, tried a different one with the same result. What am I missing here, besides the lights?
MF Poor
06-18-2006 13:00:08
 Re: Ford 5000 Lights in reply to robert wood, 06-17-2006 15:49:50
Check ground connections. Like trailers, older tractors have more ground issues than any other electrical problem. A couple tractors of mine will loose all the lights when a fender gets loose. (fender to axle housing ground connection)
Also, check the switch. With everything going at once, that's a possibility too.
souNdguy
06-17-2006 21:59:17
Follow the volts... Check power to the lamp switch.. if none.. keep going back up the line..
Is it possible the genny died and the battery is stone dead? ( diesel engine won't care.. )
Soundguy
