Restoration & Repair Tips Board
Carb. float repair
mike smith
06-21-2006 12:06:10
Question? Ever have a float that had a pin hole in it so you had to get another for 20.00 or so dollars. Try dipping the float in red koat gas tank liner and hang to let dry. Works great and if you keep red koat around it's a simple fix.
mike smith
06-24-2006 13:47:00
 Re: Carb. float repair in reply to mike smith, 06-21-2006 12:06:10
That's why you just dip the whole float in the red kote. You don't have to look for the hole in the float.
noncompos
06-22-2006 12:22:08
And when you first pull it out, and shake it to see if there"s some gas leaked inside, don"t try to dry it out by putting it on a heat source, even a moderate one...yeah, that"s learning the hard way...
Mike M
06-21-2006 13:13:14
Or you could solder them ?
souNdguy
06-21-2006 17:22:00
 Re: Carb. float repair in reply to Mike M, 06-21-2006 13:13:14
Or a single small drip of jbweld right on the pinhole..
Soundguy
old
06-21-2006 21:11:32
 Re: Carb. float repair in reply to souNdguy, 06-21-2006 17:22:00
That works but only if you can find where the hole is. I have a float from one of my Olivers that has a hole in it but I haven't been able to find the hole.
souNdguy
06-22-2006 04:55:32
 Re: Carb. float repair in reply to old, 06-21-2006 21:11:32
Submerge it in a glass of very hot watter.. look for the trickle of bubbles..
Soundguy
ChrisH(IA)
07-06-2006 13:30:57
 Re: Carb. float repair in reply to souNdguy, 06-22-2006 04:55:32
Do what souNdguy said, then cool that float off with cold water after you mark the hole. Then hold it with the hole down under hot running water to force the gasoline out of it. May have to do it more than once to get it all out. Then, using an electric solder iron and some rosin core solder, you can solder that up so fine it'll last at least 35 years. (fixed my Holley carb float back in '71-still holding)
