Restoration & Repair Tips Board
Case 580 ck manual shuttle problem
Gary K
06-23-2006 13:08:08
Hi everyone
I have a problem with a case manual shuttle that I need help with. The transmission cannot be shifted into reverse and it needs to be to remove the forward/ reverse/ hi,low cover. Does anyone know a way to get the cover off without destroying it or the for/rverse shaft?
Thanks
Gary K
lonzo
12-09-2006 19:02:42
 Re: Case 580 ck manual shuttle problem in reply to Gary K, 06-23-2006 13:08:08
i worked one over 20 years ago and remembering that i had to remove the engin and them remove the cluthc houseing at the front of the trans case and then reaching inside and removing hi low box then shuttle box, it was lot more work than i thought it would be
