Restoration & Repair Tips Board
1947 WC Allis Chalmers Leaking Lower Radiator Hose
Chuck and Mike
06-24-2006 11:50:11
We have a 1947 WC Allis Chalmers that we just replaced the radiator and hoses on. We cannot get the upper (water pump side) connection to seal. We have tried using two high torque hose clamps (4x the clamping strength of a standard hose clamp) but still cannot get it to stop. We even installed a longer hose with and little bit of Permatex 'Form-a gasket' sealant, but that did not work either. The leak is not bad - it just slowly seeps out. Does anybody have any ideas on how to fix this? Any help would be greatly appreciated.
indiana picker
07-02-2006 14:55:01
 Re: 1947 WC Allis Chalmers Leaking Lower Radiator in reply to Chuck and Mike, 06-24-2006 11:50:11
Had The Same Problem On A WD Cleaned Off Pipe Until Shiney And Put J.B. Weld On It To Fill In The Pits And Smoothed Out With Wet Finger And Let Dry, Used Permetex #2 On Hose And It Made A 130 Mile Tractor Drive And Has Not Leaked.
MPK
06-27-2006 18:43:36
You might have a lot of rust buildup on the pipe so that it has a porous surface that makes it leak slowly. Maybe try scraping it clean, or the pipe may have a crack or pinhole.
