Restoration & Repair Tips Board
2n hyd lift problem
leo g
06-24-2006 18:27:08
i just had hyd pump out and installd new releif valve. now when i raise lift to where it starts to move it goes all the way up,same when i go down. this is a tractor i just bought. exactly how does control valve work in the pump. HELP LEO
souNdguy
07-05-2006 13:25:55
 Re: 2n hyd lift problem in reply to leo g, 06-24-2006 18:27:08
You'l get way more replies if you post in the Ford 9n / 2n / 8n forum.
Did you mess with the linkages under the hyd top cover when you did the work?
Soundguy
oleo
07-10-2006 17:51:04
 Re: 2n hyd lift problem in reply to souNdguy, 07-05-2006 13:25:55
there is really not much linkage in there,on 2n maybe just a rod and fork to run control valve.and valve is not sticking.parts guy said something has to be done in pump but did'nt know what.thanks for your reply leo
souNdguy
07-11-2006 06:22:17
 Re: 2n hyd lift problem in reply to oleo, 07-10-2006 17:51:04
If you think there is no linkage.. you didn't look under the top cover.. lots of draft linkage.. and the adjustment of that linkage -WILL- effect the performance and function of the lift... The pump just pumps oil.. it has a control and relief valve.. it does whatever the control valve tells it to do.. the controll valve is controlled by the fork.. which is in turn controll by all of that non existant linkage under the top cover, which is in turn, controlled byt the hytrol 3pt lift handle on the side of the hyd top cover.
Soundguy
