Restoration & Repair Tips Board
Carburator-1939-John Deer-H
Heavyduty
07-02-2006 19:59:52
The top of carburator is cracked where gas comes in. Can this be repaired or is there someplace I can buy this part. Any ideas? Thanks John
dab
07-07-2006 08:45:46
 Re: Carburator-1939-John Deer-H in reply to Heavyduty, 07-02-2006 19:59:52
Had that problem with one and brazed it. Worked fine and doesn't leak. Make sure all gas is gone and once you do this you will probably not be able to get your screen back out. You can contact roberts crb shop and see if they can fix it also.
Heavy duty
07-09-2006 18:29:03
 Re: Carburator-1939-John Deer-H in reply to dab, 07-07-2006 08:45:46
dab thanks for the suggestion.I will try it.
