Restoration & Repair Tips Board
Ac spark plug 83s com
junk4me
07-07-2006 16:07:14
I'm looking for applications of the ac spark plug 83s com. I have a full box but ac delco says they have no record of such a spark plug. Any help would be appreicated.
dr.sportster
07-09-2006 12:10:28
 Re: Ac spark plug 83s com in reply to junk4me, 07-07-2006 16:07:14
AC 83Scom and 82Scom both cross ref, to Champion H17-A,Autolite BT4,Edison 48TS.That being from a very old cross reference chart so be careful to check for overheating if you try to use them.I have holed six pistons on a six cylinder Ford motor in a freinds van.The good thing was my Falcon motor fit right in to calm him down.It should be an 18mm thread and some of the cross referenced plugs are also obsolete.Now looking up the Champion heat range [of H17-A] I dont see it listed for any tractors at all.Nearest listed is an H10[Ford Ns] which would make H17 a very hot plug so the AC 83S com must also be way hot for tractor use. In the H series Champion H12 is hot H4 is cold.Try google.Best they can do is foul worst is hole the pistons.Mmmmmm.
